Could not add yeelight color bulb
Hi, I could not add the yeelight color bulb and I’m stuck at the select wifi network stage even though I’ve connected to the yeelink-light_xxx network it still aked me to connect to the yeelink-light and return to the mi home app. Does anyone know how to fix it?
I’m on the ios 13.1
Seems this is a compatibility issue in iOS 13, we will take a look at the issue. Currently, you can connect the bulb with an Android.
Thanks hope u fix the problem with the yeelight ios also, tried and only success on android
You can use our Yeelight iOS app to connect the bulb.
same problem here,using 13.1.3, tried on/off more than 10 times, forever stuck at 25% and i saw this problem already exist since 2017(other yeelight forum)…more than 2 yrs and not resolved…
