Hello!
I found a Yeelight Jiaoyue 260 lamp in the online store. Have you really released such a product?
If so, can it work like a bluetooth (BLE) hub, like bigger ones (450/480/650 and so on)?
This product has been released.
Yeelight Jiaoyue 260(smart version) is works like bigger ones.
It also has wifi module and buletooth module.
So it’s fully support BLE hub functionality and can be paired with bluetooth themperature & humidity sensors and transmit data to Mi Home for scenes, right?
It has bluetooth module, but cannot be used as a bluetooth gateway.
If you want to pair it with bluetooth temperature & humidity sensors, you need a bluetooth gateway.
Bad news Big one (480) can do it. Really miss this feature for small lamp in bathroom area to control fan from bluetooth sensor data
Is there any chances for this lamp, that BLE gateway feature will be available after firmware update?
The 480 model acts like a bt getaway? Even for mesh devices?
Is this light has moonlight mode? I can’t find it in menu.
