hello, since the update, it is impossible for me to connect the bulb to my phone. The setting stopped at 25%. Can you upgrade the uptdate please?
Can you help me please ? Thank you so much.
Why you connect the bulb again? I don’t think you need to connect again after the update.
I did the update at the same time that I installed the bulbs. the first bulbs was already connected and when the update ended the second was stuck at 25%, so I reset the two bulbs to start the installation and since I can not connect it anymore
Which server did you select?
Please also let me know your mi id. I will look into it.
first I chose the server usa and after I test all the others.
ID 1774220742
Hello, someone can help me please???
