Set_ct_abx on Yeelight Mijia Desk Lamp
I’m using the API to control the yeelight devices (see attached).
http://www.yeelight.com/download/Yeelight_Inter-Operation_Spec.pdf
With the Yeelight RGB bulb, everything works as expected.
With the Yeelight Mijia Desk Lamp, I have the problem, that the set_ct_abx method returns the error ‘method not supported’.
However with the set_adjust I’m able to increase/decrease the CT value.
Is that a bug in the Mijia Firmware? if yes, can that be fixed? Is there another way to set a specific CT?
Thanks in advance for your support.
Best regards
André
Ah… It’s firmware bug, will fix it as soon as possible. Sorry.
okay, great.
BTW: meanwhile I found a workaround by using the set_scene() API call. If you use it with the parameters ‘ct’,<new_ct_value>,<current_brightness> it is possible to set the CT to each value between 2700 and 6500.
:+1:
