I have read that the gateway can also be fully hard reset by using a pin in a hole in the front face… this should remove all software updates and yield it to stock: maybe this way I can reset it, because I think I did enable the accidental delete protection.
@psybill same problem here… before the last update, I can login on singapore server without any problem… with the last update, I can not see anymore a part of my equipment… everything is still working but I can not add a new sensor or modify the old routine involving these “can’t be seen” sensors…
Xiaomi… what a joke… i wanted to buy the Mi Mix 2s but just because i am so frustrated with their fake promishes, i went for another phone. I said it before, but I wish that Yeelight had their own buttons etc without the need of the Xiaomi gateway.
For the record i changed my phone about 10 days ago and now i cant access the gateway anymore (singapore) although i havent tried any of the old workarounds since i had a renovation in my house and i still dont even have the sensors fixed in the right places. If Alexa works ok with the skill in Mainland China then i will revert back to China even if everything becomes slower but in the first chance that another solution, button etc finaly works for yeelight in the future, then Xiaomi and their gateway is over for me…
Hi, need your advice, I tried many time to link SG server, only limited devices are seen like what you have mentioned, only the regular gateway and not the AC companion (both round and square version) and many other devices are not shown as compare to CN server.
And when I use CN server, I could not get it to link to Google Home, Google home said link success but MiHome has never shown up as linked Device. Tried many times.
So I thought only SG server’s device can support Google Home…and I have AC companion that does not show up in SG server. Now it is left useless.
Could you share how you get the AC companion (and many other devices)to show up in SG server? How to re-create the BOOM?
That’s an old post mate and many things have changed since then. Xiaomi seems that fixed the bug that allows us to connect the gateway and other unsupported devices to Singapore server. So, no BOOM anymore!!!
If your main concern is Google Assistant, there are some good news. Both Xiaomi and Yeelight now support Google Assistant in Mainland China Server.
Take a look on this link to check what devices are supported by Xiaomi’s Mi Home Action. There are some Yeelight bulbs included. Of course there is no support for the gateway yet.
A few days ago Yeelight started supporting Google Assistant from Mainland China server, but it’s in beta stage at the moment. If you want to join the beta program then you have to post your Xiaomi ID on this thread
Thanks for your reply. However I like to announce that the old tricks still work and BOOM still happening 3days ago. Mi Home Version 5.4.1.
My devices are all not supported in SG, for example AC companion, Zhirui light, and some Zigbee Aqara sensors. I started with The AC companion, it will only show up in CN server, after following the trick many times by switching the server to and fro, finally the SG server detected the AC device and installed with “fail to connect” error. Even though reported as failure, it shows 1 device connected, but ICON was invisible. I gave up, but on the next day when I turn on MiHome App, BOOM, all unsupported devices appeared on the add screen and I can see my A/C Icon connected.
I was so happy, I can control everything from SG server using MiHome App.
and I thought now I could linked to google Home, However, my dream crushed as devices still cannot be seen on google home app.
So the conclusion is, Even if I manage to make SG server to link to all unsupported CN devices, I still cannot get Google home to work with them, Google home just can’t see the unsupported devices.
Another announcement, yesterday 16Aug, the MiHome APP has a new revision update 5.4.5, After I did the update, the SG server BOOM again, all the unsupported devices disappear from my screen again. By now I am too lazy to retry the trick again to fool MiHome App. I am too tired, simply give up and start to use CN server without using google home voice control.
Just like to share the above experience for those who are in the same path…and it will save you a lot of trouble.
Hi, Any chance to get google home to work with China server on all the unsupported devices? like AC companion and Zhirui light. All these devices are not supported outside China. I am in SG.
Thanks for your help.
I can confirm that if you have luck and try enough then the old ways are still working… although i reverted back to China server either way (remembered that i have a camera that is not working in Singapore server so…). Alexa works ok in China through mi home skill…
thanks for the feedback. does save me lots of trouble trying again. SG server not fully supported and it’s too troublesome for all the workaround and trying luck that it will work. this approach is not sustainable. guess will be like you and just give up, back to CN server.
I have several Bulb Color v2 with the aqara smart switch + gateway and i CAN’T get it to work because i need to use CHINA SERVER and if i use the china server, ALEXA won’t discover the lights because it will only discover it if it is on US or SINGAPORE server.
I need bouth MI HOME and YEELIGHT working with the same lights so i can use alexa to control the lighs with yeelight skill AND use the smart switch to turn on and off the lights from MI HOME app.
Will SINGAPORE SERVER support bulb v2 and all others, whats the ETA, i have no use for everything i bought since right now to use it i’ll have to give up alexa.
It does not work, when i setup the bulb on one server, i can’t find the bulb on the other server, it is only possible to setup the lights on one server.
anyone here has a gateway from hong kong (https://www.mi.com/hk/mi-control-hub/) and managed to connect it to the China server? i seem to be able to connect to non-China server only…
