I’m using bulb color. I want to use it with LAN network so as my thought, I suppose its operation is following:
First , when Using bulb, we fill our router and connect to its wifi in setting, so, at that time, we connect to it and supply it can be access to cloud with our router and it makes webserve with it’s default IP address,right?
Second, when we controll it via Yeelight app. It means the Yeelight app will send a trigger to cloud, and the cloud will to send a response ( maybe GET or POST) to webserve and the Bulb will read it and acts, right?
Next, If my thought is right, so if I have 2 or more Bulbs and we know the their default adress is the same :239.255.255.250. So if I controll it as above , it will be mess, Please explain me for that.
Thank you
