but I receive this:
{“id”:(null), “error”:{“code”:-1, “message”:“invalid command”}}
What am I doing wrong? I’ve spend a few hours trying different variations.
The bulb is setup correctly because I’m able to use this command to turn the light off
echo -ne ‘{“id”:1,“method”:“toggle”,“params”:[]}\r\n’ | nc -w1 192.168.1.136 55443
You directly sent the discover message to IP and port of the bulb, that’s why you get the error message. If you know the IP already, it can’t be called discovery…
The discovery message should be sent to a multicast address using UDP.
I have also tried:
echo -ne ‘M-SEARCH * HTTP/1.1\r\nHOST:239.255.255.250:1982\r\nMAN:“ssdp:discover”\r\nST:wifi_bulb\r\n’ | nc -u 239.255.255.250 1982
but nothing happens, after a few minutes I canceled the command.
I’m assuming the http request is correcty formated, then can you suggest a correct nc command?
First of all let me thank you that someone from the Staff it’s actually taking time to help us - the users. It really makes a difference.
I think you are right, netcat-openbsd might not support multicast.
What I was trying to do was to get the supported control methods, mainly. But I managed to get it using the available python script.
