Device is not connected yet
Hi guys,
I’ve connected yeelight bulb through my ios app but when i tried to use chrome demo, it shows device is not connected. How can i fix this?
Best regards.
You need to turn on developer mode in Yeelight app.
I solved the problem! These bulbs unfortunately do not work well to set it up with 5G wifi networks. Surely the problem gave the coupling the bulb with the 5G network, ie with more than 50 Mb down. The first installation should be turned off and the lamp should be turned on 5 times until the bulb starts flashing with colors. Then we connect to the 2.4Ghz wifi network of our router, we add with the application our bulb when it asks. At first it will stay in 25% of the installation but have patience, because in minutes it will be 100%.
