I am new user to Yeelight. From app I should connect to my home wifi but its displayed as public and wont let me connect
at home i have 2 wlan notworks
one public
one private with password
your app wont let me connect to my private wlan
blocking bug this way
Is the private network 2.4G or 5G?
wow thats fast response
i tried again and could connect now to home even its displayed buggy
check screenshots
https://photos.app.goo.gl/iWfzxTwe05xhoY6o2
check out the other pics
https://photos.app.goo.gl/oihBjHzUj66nDmZT2
the wlan detection has critical bug
i cant downloD THE beta app can you give me a working link?
Do you have password with your home network? The bulb need network with password.
yeah check the screenshots
i have password for “home” wlan but your app bugs
my router opens 2 wlans
one public and one private
your app bugs out in this case
try changing your Wi-Fi security method to WPA/WPA2-PSK if you have it on “shared key”. That’s usually under Network/Security/WLan in your router’s interface
its a bug in the yeelight app. No need to change router setting
which one is the private network you want to connect?
hi I tested now the beta which is buggy too
my home network is called “HOME” which is password protected
https://photos.app.goo.gl/jdP8tW5xLacs51OF2
https://img2.picload.org/image/dgowpplr/germanwlanmesh.png
here you can see the WLAN layout its MESH now which is default for german market
Fritz box is very common in germany so i guess you should fix your app
beta and stable had the same issue with wlan detection
to checkout and fix the mesh issue just get a fritzbox and a few 1750e repeater like i did
the WLAN Mesh should work as its default now in germany
You private network “Home” is 5G, right?
Hi, please try to set different names with 2.4G and 5G, the bulb only support 2.4G network.
BTW, this is actually an issue of the prompt text, we will try to fix it.
When the Bulb only support 2,4g it will not see the “5g home” at all
because of WLAN mesh I cant change the SSID they must be the same for handling
I guess your app is not WLAN Mesh ready
its now the default standard from Google Home etc so I guess you shoudl add Mesh support asap
Google Wifi - Home Mesh Wi-Fi System - Google Store
I got got only yeelight for testing (which doesnt right now) but I am thinking about fit all the house with smart lamps once its working
I manged to add the lamp to my wlan despite the bugs from the app
its working now
