Hi all.
Please, help me to solve my issue with connection.
First, my id is 4150909640
Every time I receive “connection timed out” error. What I tried to do:
- Reset bulb.
- connecting via other server (Germany, USA, Singapore, China)
- Connecting via hotspot of mobile (4G)
No one help
