I have a new bulb.
I plugged it, but my ios app wont connect, it’s stuck on 0%.
I deleted the app, reinstalled it, logged out, changed all servers, nothing.
It just won’t pair at all.
Is this thing even working for someone?
PS: i tried three different iphones. The app is stuck on 0%.
PPS: i resetted the bulb 3 times.
Can we get refounded for something that is not working at all?
1)Reset the lamp by power on and off fives times 5 times in a row, and then see if there’s AP named like “yeelink-light-***” in your phone’s wifi list? If yes, go to see Step 2; If no, it means there’s something wrong with the wifi module of your lamp;
