Cant connect with my wifi. only with personal hotspot
hello, why i cant connect my bulb with my wifi? only with my personal hotspot from other phone. pls help me.
Please make sure that your network is running on 2.5 GHz, 5 Ghz is not supported by the bulbs.
You need to go to your Router Config Website and you need to change the Security to WPA2. Usually many Routers are Using WPA/WPA2, that protocol mix cannot be used by many devices. So if you set it to just WPA2 it helps a lot, also it makes your Network much more Stable.
That also solves most problems with other Xiaomi Devices.
Please make sure that you server region is Singapore if you’re not in China mainland.
