Hello !
Yesterday I received my Yeelight and I plugged it on a lamp and tried to connect to my smartphone.
After I installed the Yeelight application, I tried to connect to the wifi (the application sees the Yeelight Mac address and I can try to connect) but then I have an error “Couldn’t find any available wifi Network”
I don’t know what is happening but if you know please help me !
The bulb only support 2.4G Wi-Fi network?What’s your network, 2.G or 5G?
I have to check at home I keep.you in touch
I have a French Freebox Crystal which is in 2,4 GHz so it should be good but still the same problem…
Even if I try with mi-home I have this
But it’s already allowed in the settings…
Try changing your Wi-Fi security method to WPA/WPA2-PSK. That’s usually under Network/Security/WLan in your router’s interface
It worked ! Thank you very much !
