Tried a few restarts, the remote linked & works but does not change the color temp.
Also, I don’t see where I can change the temp using Yeelight iOS app, and when I’m trying adding color temp scene/frame I’m getting “not supported”.
I am also facing the same issue from a long time but I am not getting any solution with this.
If anyone is availaible with this, please share it with us. Google Customer Service
Thank you for the quick answer.
The description of the product (Ordered it from Gearest) is:
“allows a flexible adjustment of brightness and color temperature.”
Adjustment of color temperature.
So it is very confusing.
So the main description misleading & says its adjustable, but hidden down in the Q&A it says the opposite. You need to highlight this information in the main description.
OK, thank you for your quick answers.
