Adapter size
can someone share the size of the adapter of the lightstrip (height width depth)?
I can’t find them in the product specs and I need to install the lightstrip in a countertop
Will be at home in 3 hours. have one power adapter on my desk, since I cut the cable to change to another power supply, which is smaller :stuck_out_tongue:
If that is enough, tell me.
Yes thanks, and if it is too big I’ll probably do the same for my strips
FYI: The ground wire of the power brick is made like a shield around the insulated “hot wire”.
Got my new power supply at amazon and it barely fit, where I wanted :smiley:
Now I’m hoping for longer LightStrips, since I don’t manage to open the controller box.
Maybe someone has managed this and knows if it’s possible to exchange the strip by another one?
HxWxD: 65x30x50mm (it’s “0”-shaped, if you understand, what I mean) + 15mm for the socket input
this is the size of the original power supply
hope this helps a bit.
sorry, that I post it that late, but had to go somewhere before.
Kind regards Lukas
Thanks for your answer Lukas, with “0”-shaped you mean that the edges are slightly rounded?
It’s too bit big for me, can you tell me name of the power supply you bought on Amazon?
Kind regards,
Adelfio
