Struggling to get music mode to work…
It works fine from the yeelight app, but commands are encrypted from yeelight so I can’t see exactly what it is doing.
According to specification, it should be working, here are my logs: -
DEBUG listening 0.0.0.0 on 10186
DEBUG Music mode ON 186 <- { “id”: 1, “method”: “set_music”, “params”:[1, “192.168.1.1",10186]}
DEBUG response: 186 -> {“id”:(null), “error”:{“code”:-1, “message”:“invalid command”}}
telnetting from another machine on that network (also via wifi) to gateway (192.168.1.1) on port 10186 connects to the listening service fine.
DEBUG connect
DEBUG got [test]
Can someone please check my packet structure above, i’m pretty sure it is sending fine?
Also note that the “invalid command” response seems to occur after a second or so (internal timeout) in the yeelight.
I’m running 1.4.1_48 and RGBW model (YLDP02YL)
Thanks for your help!
David
