Just got a yeelight lightstrip and everytime i try to connect it, it says connection timed out check your network and try again after the connection process hits 100% i’m from india and joined to the singapore server if anyone could help please.
And could you post the ping result of "sg.ot.io.mi.com”、"ot.io.mi.com”、us.ot.io.mi.com” and de.ot.io.mi.com”?
i can see the yeelight in my wifi list and there are no special characters in my wifi name when i try to add a device everything goes well until the process hits 99% and then it says connection timed out , check current network and scan again. i have very little knowledge about what you said in step 3 should contact my isp provider?
Please help confirm the following things:
1、See if the lamp in your router’s DHCP list.
2、please post the ping result of "sg.ot.io.mi.com”、"ot.io.mi.com”、us.ot.io.mi.com” and de.ot.io.mi.com”.
can see the lamp in my routers DHCP list
tried to connect again the same error shows up with a stable blue light on my lightstrip
CONNECTION TIMED OUT i have reset the lightstrip about 20 times now can someone please give me a fix for this.
Please post the ping result of "sg.ot.io.mi.com”、"ot.io.mi.com”、us.ot.io.mi.com” and de.ot.io.mi.com”.
ping sg.ot.io.mi.com
Pinging sg.ot.io.mi.com [52.221.85.229] with 32 bytes of data:
Reply from 52.221.85.229: bytes=32 time=105ms TTL=48
Reply from 52.221.85.229: bytes=32 time=107ms TTL=48
Reply from 52.221.85.229: bytes=32 time=114ms TTL=48
Reply from 52.221.85.229: bytes=32 time=102ms TTL=48
Ping statistics for 52.221.85.229:
Minimum = 102ms, Maximum = 114ms, Average = 107ms
ping ot.io.mi.com
Pinging ot.io.mi.com [120.92.96.248] with 32 bytes of data:
Reply from 120.92.96.248: bytes=32 time=309ms TTL=43
Reply from 120.92.96.248: bytes=32 time=312ms TTL=43
Reply from 120.92.96.248: bytes=32 time=311ms TTL=43
Ping statistics for 120.92.96.248:
Minimum = 309ms, Maximum = 312ms, Average = 310ms
hey did y’all find a solution? im still not being able to pair it
The result looks well, so there must be something wrong when the lamp try to connect the cloud. Could you have a try with changing your router’s DNS server to 8.8.8.8 instead of using automatically allocation?
Hey. I had such a trouble too, but found a solution. Maybe it will help you too.
You should to change DNS server in settings of your internet router.
You can use 8.8.8.8 or 8.8.4.4, they are servers of Google and they are free, so I use them by myself.
Try it out
where do i change it from?
i dont have a lot of info can you give me a simple solution? its been so many days i cant get it to work with the same error
This is in your router’s settings, you can google it
I am sure that there’s something wrong when the lamp try to connect to the cloud. Maybe you could ask your ISP for help
so theres nothing i can do and i have a pair of lights which i cant use?
From experience, most of the errors people get are either from ISP or local router settings… try examinig your router settings. Or take another phone and try making hotspot and connect to it.
