Hi, I’m trying to connect the bulb to wifi using Mi Home app - however, unable to do so. Please help.
- IOS 11.4
- Router DLINK DSL-224
- App: Mi Home
- Region Selected: Mainland China
- ID: 1797518192
- Steps: Mi Home App > Add a device > Select Model > Yeelight Color Bulb > Device Power on (after reset) > Connect to my Wifi > Wifi Settings > Connect to “Yeelight… > Come back to Mi Home app > Connecting… 1-100% > Device Reset screen.
Please help. Thanks
Make sure that security wifi is only TKIP
