You can try to use hotspots for firmware upgrades, I just tried my color bulb, the firmware was updated from v1.3.1_37 to v1.4.2_0062 successfully, it could be a network problem.
I have problem that I click on update but for few minutes there is 0% and “updating” and then back to page where it was - “Actual version 1.4.2:…” - “Newest version 2.0.6_…” - “UPDATE”. So, I click on UPDATE, 0% and back there. Not working. Europe.
I’m in France, so Europe server, and I can’t update any firmware of my 10 yeelight bulb color 1S. When I click update , it seems to load for a second and then the update button came back. I click again, same thing.
From 1.3.2-0018 to 2.0.6-0024.
I want to update because they keep randomly disconnect briefly.
@thomasj
Do not make an update of your yeelight bulbs color 1S to 2.0.6-0024 firmware. It’s faulty. The bulbs will be unusable after update.
I’ve made an update to 2.0.6-0024 firmware. After that my 1s bulb went offline and I have no possibility to connect it again. Full reset and reconnect doesn’t work. See my topic.
I managed to update both my bulbs from firmware 0024 to 0034. I was getting the same error as everyone else, but I found a way to get around it. Here’s how:
There seems to be a random delay between the app and the bulb itself. Sometimes it takes up to 5 seconds to change color, other times it’s instantaneous. Switch the bulb on and off, close and open the app, until you find a moment when the sync between the app and the bulb is very short. That’s when you need to try to update and it will work.
