我本人使用的灯带型号是 YLDD01YL,进行开发中发现还有 YLDD02YL 型号。从功能外观上感觉两者没有什么不同,但是在开发中发现开启开发者模式后,程序获取 RGB 信息受阻,能否问一下这两款灯带的差异?
I’m using Model YLDD01YL and found out that there is Model YLDD02YL during development. It seems like no differences between this two models from appearance and function. But typically when I launch the development mode, the code capturing RGB values didn’t works on YLDD01YL but works well on the other. Could I ask the differences between this two models? Especially on core level. Thanks.
