I can find my Yeelight Ceiling Light in my Mi Home App and in my yeelight app.
i can control tje lamp with my smartphone.
My problem is that i cant pair my Remote with the Yeelight ceiling light.
I pressed “off” and “M” button on the remote and i also restart the Ceiling light by turn it of and on for many times.
Power on Ceiling Light with the switch not from app, then press “OFF” and “M” button on remote at the same time, while the indicator starts blinking indicate that remote start binding. (You don’t need press the button all the time)
Same problem here, lamp is working fine with wall switch and app, but not with remote. Binding proces went ok, wall switch on, after couple of seconds “OFF” and “M” button on remote, remote starts blinking rapidly for a sec, then starts flushing let say every second, after 2 seconds (sometimes after 8 second, sometimes after 15 seconds) ceiling lamp flashes 4 times, remote led stops blinkig, so everything seems ok, but remote doesnt work. I can’t turn light on or off, change the temperature or change brightness. Did that 10 or 20 times but no change.
1.4.8_168 In MiHome app “no remote bound”, in stable Yeelight app was also “no remote bound”. But on beta Yeelight 3.0 I’ve installed today in remote section I see remote and can control light with it.
I already did, several posts above. “1.4.8_168 In MiHome app “no remote bound”, in stable Yeelight app was also “no remote bound”. But on beta Yeelight 3.0 I’ve installed today in remote section I see remote and can control light with it.”
Is it official yeelight forum!? Can I get a straight answer!? “Yes we know that problem, it will be solved in the next firmware update” or “your lamp is broken please send it back to the seller”
