i’m in Turkey and i have yeelight e27 colored bulb. bulb working but my iphone never connect to server.it’s stuck %25 connecting to server. i try mihome and yeelight app. When i’ve try android phone and connection timeout. My router settings is correct. Ping to server ok. i try almost all way in this forum but my problem is not solved. This only working 4g hotspot! what can i do for this problem? i want to use wifi.
Ping your servers is ok. i was talked my isp on the phone he says we can nothing do this problem. It’s very disapointed problem. Any help? Or i will want refund to seller
İ’ve exact the same problem. Its not from the internet provider, many owners from yeelight use it without problem but many people can’t use it, the main problem is “connection time out” issue. İ’ve tried the connection with many phones/tablet the yeelight app see the bulp but at %99 break it up with the error " connection time out " try again. I’ve tried may times with reseting but all the time the same. It would be very helping if you guys solve this ugly problem because i’am not the only one with that problem, half of the buyer have this problem, it is very important for the future of this lamb and Xiaomi brand prestige. I accept problems while it is complex technologie but i big and serious brand must solve the problems immediatly. That is fact. Please for reacting. Thank you.
Your router sometimes has both 2.4G band and 5G band, you can give them different SSID and Password, you can also use one SSID for both. For 1, I mean please give 2.4G band a dedicated SSID and try connect your bulb to it.
For 3, logon to your router’s management portal and see if your bulb is present in DHCP client list.
Hi guys… I had the same problem… but was trying to connect to my 5.0 instead of 2.4… by changing my WiFi connection, reseting the bulb and redoing the setup… all works good.
