In the API there is a command called “set_music” that makes the lamp take commands from a server that converts music to color commands. Have anyone successfully hosted a server locally on your PC and connected the lamp to it? If so what software did you use to host the server? Thanks
It doesn’t convert music to color - it just sends colors.
How do you mean? I had the understanding if you had a server that converted music to color commands you could connect the lamp to that.
What server?? I am not aware of any such server to convert the music to colors The API command just sets the bulb in receive mode to listen to specific IP adress for colors. What’s on the other end - you have to supply… The API command/bulb doesn’t care what server does. It doesn’t have to convert anything, it just sends commands (colors)…
You should write this program, I would like to use it.
