Just wondering is music flow supported by the strip lights I have 2 color bulbs and 2 strip lights and I get an error message “music flow failed” when I try to use them with the strip lights
Should be supported. Try starting it off a different decide, Android works very well. Then try different wifi or restart app. If all else fails reset the device and set up again. It may also just be the software it’s running so you may have to wait for next update.
Hope this helps,
Thomas
Music flow works with my LED strip. Your device must be on the same WiFi network as lights.
