I’m unable to detect my light strip in either app. My Yeelights bulbs are working perfectly. I do not see a lightstrip wifi network being broadcast.
I’ve reset everything I can think of. Please help.
So it seems you stuck at the first step? Please double check it.
No yeelink-light AP. I’ll contact the vendor.
