IPv6 and Yeelight?
I’ve just started playing with the IETF Homenet which is IPv6 based, not IPv4. I’m getting an IPv6 prefix from my ISP to my router. My laptops, Raspberry Pi’s etc are getting a global IPv6 address from the router. I restarted my colour Yeelight but it doesn’t seem to be IPv6 enabled, not showing on sudo nmap -6 --script=targets-ipv6-multicast-*. Ping 6’ing the probable link local address didn’t show anything either.
Can the Yeelight bulbs talk IPv6? Particularly interested in LAN control over IPv6.
No response? Let’s rephrase the question. Are there any plans to add IPv6 to the Yeelight range? If yes, what is the expected timeline?
Thanks, Jan
I use IPV6 because it is a support to my system with a peer-to-peer model of TCP. It helps me fast and less problematic. IPV4 is damaged my touchpad which is solved by hp touchpad not working so you can visit for your solution
