I just received a Mijia Desk lamp and a Ceiling Light 450 and I have a problme with Google Home integration.
When I ask Google Assistant to swich on or off my lamps, only the Desk Lamp respond. I always have a message saying “ceiling light in not available” (or something like that, I’m using it in french language). I’m able to control the light through Yellight app. I’m registered on the Yeelight german server.
I tried to reset and reassociate my ceiling light multiples time, but I got no luck in making it work with google assistant.
@NoX330
Hi partner, if you change server to German server, you should tell GoogleHome to sync devices, you can say: “Hey Google, sync devices”, when GoogleHome sync successful, please try control it.
My ceiling light reseted and I have exactly the same problem than before. When I try ton control it through Google Home, i have a error message “an error occured”. I tried to unroll device from Yeelight app, resync devices on Google Home with no success.
I tried to reboot my Google Home with no success un controlling my ceiling light. I have the same symptoms on Google assistant. I have both a ceiling light and a mijia desk lamp on this room. When i ask to Switch light on, only the desk lamp power on, Google tell me there’s an error with the ceiling light.
Nevermind, I had a bug in Google Assistant and my ceiling wasn’t assigned to the room. Instead, I had a classic bulb which is mounted on a lamp with a swich (and which is powered off).
Thanks for your help, i’m really sorry and feel a little dumb
