before: 30 seconds to put all light ON (24 Bulb about…)
now with firmware 1.4.1_52 : 6 seconds
This change a lot the story.
If i move in the corridor the light turn ON automatically and instantly.
Before was kind of “walk in corridor and light turn ON after 5 seconds when i was already in another room”
Guys, have there been changes in music mode in new firmware update? I have noticed a bug in my app that wasn’t there before and started after I upgraded firware on color bulb and LED stripe.
I turn on music mode and run tcp server, issue commands to tue bulb.
When I turn the bulb OFF, it terminates the TCP connection. I am sure that before, I could turn the bulb off and back on and the music mode would remain and it would continue functioning.
Yes, this is introduced by the new firmware but it is a behavior change per design. The old behavior, where the music mode was kept silently on when bulb is turned off, was somewhat counterintuitive. Resources (restricted and precious) are unreleased while bulb is switched off, or released ungracefully when the phone wanders out of the LAN network. That’s why we took it a defect and fixed it.
OK, thanx for the confirmation. I was just wondering why my program stopped working I’ll have to reopen tcp session when the bulb turns off and back on.
I updated the firmware yesterday and instantly noticed, that the red is not red anymore, bur definitely orange. Does anyone else have the same problem? (Because this certainly is a problem for me). Note> I tried randomly sliding the color changer and sometimes for a moment I get the correct red color, but then it gets orange.
I wonder if someone could tell me how to downgrade the firmware to 1.4.1_52.
after a small period of time where the Lights was working fast they now starting again to work slowly.
My fibra channel line is Vodafone Italia - 100MBit/s
I checked 10 days ago the quality of that linee and it was 100% clear signal (that means there are no packet loss…)
Router is XIAOMI Router 3 (just received 10 days ago)
Problem:
A) Some Yeelight just wake-up with 5-6 seconds of delay
B) If i run a scene “Living Room On” that contains 4 Yeelight then I’m able to have the Living Room
ON after 20-30 seconds…
At this point I want to ask you if is possibile to remote-debug that problem?
What if i can give you my Xiaomi ID/Date/Hours when i got the issue and then understand why this happen? Is something possibile?
I just spent 1 month to check VDSL Fiber, changed the Router, and now the problem happen again. Hope you can help.
Most of the time the delay is 1second.
Sometime is 6seconds.
If there is a delay because of China-Server then I’m expecting 6 seconds all the time.
But this is not the real case…I don’t think this is the real cause of the delay.
I think some Yeelight product has internal WiFi issue.
I have 3 Bulb + 1 stripe led in the same room
Bulb are 2meters more away to the WiFi then the Stripe Led (that is 1meter away from a Mi WiFi Repetear)
While ping the Stripe, i received a lot of packet loss / timeout or in the best scenario the ping is around 500ms. The Buld Light ping is always good, no packet loss, average ping 10ms.
Configuring a Static DHCP (suggested from one user in the forum) has help a bit.
Anyway there are product with poor WiFi reachability i think.
Now i moved 50cm on the right side the Stripe Led, the ping is better (over 50 ping I’m able to lost only 4-5 packet).
My suggestion is to notify the User with an Alert in that cases “Hey, the WiFi is poor”.
In my case i cannot improve more the WiFi, but with this type of message i can understand that the Stripe LED has a problem and maybe consider to return back the stripe (I have 4 stripe, only this one is making me crazy!).
1 Gateway (8 SwitchButton + 8 sensors) = connected to the Xiaomi WiFi Router 3
4 Bulb + 1 strip (*) = connected to the Xiaomi MiFi Repeater.
16 Bulb + 3 strip = connected to the Xiaomi WiFi Router 3
(*) the strip with the packet loss, and Ping at 500ms. To be clear all other devices connected to the MiFi Repeater has a good ping even if they are more away from the Repeater!
I want underline that configuring Static DHCP has helped a lot.
Now i will try to ping one-by-one each devices that is causing Delay over the servers.
I wonder when Yeelight Team will release the update to 1.4.1-53 for older bulbs in Singapore Server?
Now I have a chance to set up my new home with Yeelights and discovered that some of my bulbs are older builds and the firmware stay at 1.3…1-8 or something and cannot upgrade to the latest as other newers.
Please do it fast or I have to swicth to China temporary for the upgrade to happen?
