好,大概预估多久可以解决?
如果问题在我们这边,应该很对就能搞定。如果在亚马逊那边,就不好说了。
那拜托了~ 还挺想快点体验你们这个的~ 查出来是哪边问题了随时更新哈~:joy:
(刚试了下 还是同样的报错… 北京时间下午4:30 )
(用美国的和加拿大的账号都试了一下,还是不行。 同样的报错。 北京时间下午6:04)
@weiwei (好像没法回复了,那我就在这里更新测试状态吧… 测完@你一下)
你试试能成功吗?
凌晨1:23测试,还是同样的报错,没有成功:joy:
我们再看看
有进展了么
解决了,你试试
I’ve been using IFTTT with Yeelight for quite some time now, I have two suggestions:
Would be nice if there was an option to control group/multiple lights using one applet (yes the workaround is to use multiple applets with the same trigger - which is annoying - , or use a scene - which is not flexible -).
Another thing is the blink notify scene, would be nice if the user could control the color/brightness/amount of blinks of the scene.
Thank you for the great product and active support!
你好,我也将Yeelight切换到新加坡区了,但是米家里一直没有出现这些灯。请问您是怎么操作的?是将米家也切到新加坡区了吗?
是的,米家和Yeelight使用的是同一个服务器,你把设备连接到新加坡服务器,对应的应用也要切换过去。
If you want to use Spotify on Alexa, then you may need help from some third-party tools. You could use the DRmare Spotify Music Converter for Windows, or other music converters to help you. After then, you can download and get Spotify music on Alexa for playing with ease.
Thanks for the information, I got a similar tool called Tunelf Spotify Music Converter to convert spotify music to MP3 then play on Alexa . works like a charm.
