i´am using de Ceiling Light with a wall switch. So as configured in the Yeelight App with every switch to power on the default state of the lamp starts.
My problem is now, that i want the lamp to start the moonlight function in the night when it´s switched on and not the default.
Activating the moonlight function in the app does not help, although i tried time planes.
Is there any chance to realize this function?
Ok, I understand.
Turning on and off with remote is no solution. I use a motion detector, so I don’t want to search the remote before having light…
Is it possible to create a function that changes the lamp status after connecting to the network?
For example I can make weak light to default an when the lamp is switched on and is connected to network it changed to brighter light.
Technically yes. But I don’t think that’s a common requirement, because it usually takes 7~8 seconds to get connected, if the lamp was kept in low brightness for that long, it’s kind of weird.
