Can’t connect light color bulb 1 to google home, my ID is 1757470612.
Any help? what’s the correct procedure?
1)Reset the lamp by power on and off fives times 5 times in a row, and then see if there’s AP named like “yeelink-light-***” in your phone’s wifi list? If yes, go to see Step 2; If no, it means there’s something wrong with the wifi module of your lamp;
