Hi when I do the 5 power off/on to reset the bulb will flash through colors then blink off on white several times then cycle through the same again. Eventually it just goes off. I can never link to it ? Thanks
What voltage do you use? Does is match voltage print on the bulb?
Actually I’m in the US And the bulb does say 220v . Didn’t realize that’s what I got. I received 2 bulbs and there both the same. The one works fine. Was that just luck with the one. So they shouldn’t work with 120 volt? Thanks
I don’t think the bulb(220v version) could work with 120v. Are you sure both of your bulb are color version?
Yeah, it is lucky and abnormal
Yea, they are the same and 220. It will only program in the room with my router. At least now I know why they were a pain and the one didn’t work, Thanks and have a good day
